When a user tries to sync his Notes calendar with a Palm using AvantGo, everything seems to work except repeating meetings. When the repeating meeting entries are synchronized, they cannot be opened in Notes again. The user gets a “Document has been deleted” error. Yet the entry still sits in both places. Does anyone know how to fix this? Thanks in advance.
Subject: Problem synchronizing calendar with Palm
Eric:
I would suggest you go to AvantGo support on this one …
I assume when you say you’re using AvantGo, you really mean you’re using AventGo’s Pylon Pro product … and they’ve got a pretty good track record for supporting their product.
I’d suggest you get with them directly.
- Rob
