Problem in Rich text Filed?
Hi all,
Please tell me any one how to show rich text field value value in a view?
Subject: Problem in Rich text Filed?
RTF cannot be diplayed in view.
You can try a work around …
Say the richtext field is Body
Add another text field in the form …say Body1 , keep it computed.
Give formula for the field as
plainText := @Text(Body);
plainText
Display Body1 in the view
You can also give the formula above as the column formula …
i have not tried this …you may try and tell me the result.
Bye
Siddhartha
Subject: Problem in Rich text Filed? : one more point
one more point to the above …all formatting & attachments will be lost.
Amar,
Check @Abstract function , It will do for you.
Cheers
Rishi
