Problem in printing embedded views
Dear All,
I have a embedded view in a form.
This view has a lot of documents.
When I print this form, it prints only the documents seen in the screen.
But I want to print the entire list in the embedded view.
If I print the view separately, i.e, without embedding, its printing the entire doc list fully.
But the customer wants some title and other static data to be printed b4 the doc list.
Please help me if anyone of you know how to print.
Thanks & Best Regards,
Nandhu
Subject: Problem in printing embedded views
Cant be done… only way is to show more documents in the embedded view
Nandhu, I have the same situation and am attempting to build a dynamic table to display the contents of the view on a report form. This probably will not work for large views though, as the table data field has a size limit. HTH
Roger Hintz
It sure would be a nice enhancement to have a ‘fit to content’ vertical size setting for embedded views. (hint, hint, Lotus)
