Problem in Post Save event ---For some reason the document is not closing , I have to manually hit the escape key to close the current document---Please help
Hi All,
I am having a problem in the Post save event
When I am running the code in debugger , where my last statement Call uidoc.close —doesn’t work , my document is open and i have to manually click the escape key on the keyoward to close the document…
Please help …why do I have to manually click the Escape Key
Here is the code in the PostSave event
Dim uidoc As NotesUIDocument
Dim user As String
Dim AI As String
Dim ALI As String
Dim RT As String
Dim userName As New NotesName(session.UserName)
Dim memodoc As NotesDocument
Dim newdoc As NotesDocument
Dim db As NotesDatabase
Dim recipients As Variant
Set db =session.currentdatabase
Set uidoc = workspace.CurrentDocument
Set newdoc = uidoc.Document
'Set newdoc = Source.Document
user = username.Abbreviated
AI = source.FieldGetText( "claimApproverSorted" )
AIL = source.FieldGetText( "claimApprovalList_RejectedList" )
x = user
y = Cstr(Now())
p = newdoc.claimApprovalProcessComplete(0)
RT = newdoc.claimStatus(0)
Dim q As String
q = newdoc.claimALRLImplode(0)
If Lcase$(AI) = Lcase$(AIL) And p <> "1" And q <> "" And RT <> "Draft" Then
	Set memodoc = New NotesDocument (db)
	Set rtitem = New NotesRichTextItem( memoDoc, "Body" )
	Call rtitem.AppendDocLink( newdoc, "Claim" )
	Call rtitem.AddTab( 1 )
	Call rtitem.AppendText( newdoc.claimClaimID(0))
	Call rtitem.AddNewLine( 1 )
	Call rtitem.AppendText("Product Category:  " & newdoc.claimCategory(0))
	Call rtitem.AppendText("Brand Name:  " & newdoc.claimBrandName(0))
	Call rtitem.AppendText("Type of Claim:  " & newdoc.claimClaimType(0))
	recipients=newdoc.claimDBAdmin
	memoDoc.Principal = "Claims Administrator"
	memoDoc.Subject = "The Approval Process for this Claim is Complete"
	memoDoc.SendTo = recipients
	memoDoc.Send(False)
	newdoc.claimApprovalProcessComplete="1"
	Call newdoc.Save(True, True)
Else
	Call uidoc.Close
	' the code above doesn't close , I have to manuaaly click the escape Key on the keyboard
Please help
Thanks in advance,
ac ac
Subject: RE: Problem in Post Save event —For some reason the document is not closing , I have to manually hit the escape key to close the current document—Please help
If the problem only happens while debugging, I wouldn’t worry about it too much. Sometimes the debugger can get confused about which is the current window you’re trying to do UI operations in.
