Hi,I have developed a web-based application.When i open it in IE its run fine but when i am going to run in Mozila Firfox,some menu in the rightside of the homepage are missing…Not Displying…Whats the problem with that…
Pls Help me …soon.
Pls Help me …soon.
Subject: Problem in Mizila FireFox
Internet Explorer does not follow the web standards followed by Firefox and Opera, MS always make it’s own “standards”.
That’s why some features will work on Internet Explorer and not in Firefox; and some other features will work on Firefox and not in Internet Explorer.
This is not a Domino/notes bug, it’s a “MS IE bug”, that’s why it’s always good to test our web applications in all the browsers we can (IE 6, IE 7, Firefox, Opera) and try to use only the standards used by all the browsers.
Yor problem can be being cuased by many things… javascript, java applet, Flash animations…
tell us what, exactly, is not being displayed in Firefox
Subject: RE: Problem in Mizila FireFox
everything is shown ,but some part of header meny is cutting.Actually in header menu 4 item. two on left and two r right.
Left part is home and Profile.
Right part is Admin and Logout.
In Logout only L is Shown and ogout part is Cut.
Waiting for Reply…
its Urgent.
i mean… items not showing are Java applets, menus generated by javascript, flash animations…
btw… do you have the page on a sever we can check via internet ?
