When trying to open a user’s mailbox for a number of users with 8.5.1 basic - periodically hangs client lotus. In the Task Manager process notes.exe during hang takes 90-95% CPU time.
If I try go to this problem mailbox through “all documents” view - the box is opened normally, but when I try switching to the “Inbox” - hangs again.
Then I try open this mailbox from another lotus client (7.0.3, 8.5.1 standart) - “inbox” folder opening normally.
I run fixup, compact, updall on problem mailbox - no result…
The problem in about 10 users out of 300.
Configuration all 300 users standart:
Mail template 8.5.1
Clients upgraded from 7.0.3 to 8.5.1 basic using smart upgrade.
Windows XP Prof.
