I installed domino 652 on redhat linux ES 3.0 but everytime i run the /opt/lotus/bin/server there is an error pops-up " its an .so file that cannot be found" pleae try to give me inputs, thanks in advance
Subject: RE: problem in installing Domino652 on redhat
Subject: problem in installing Domino652 on redhat
Reinstall, something didn’t copy over properly.
thanks for your inputs but i’ve tried to re-install for almost 5 times but i’ve got the same error, this is the exact error “error while loading shared libraries:libstdc+±libc6.1-1.so.2:cannot open shared object file: No such file or directory”
I am using redhat 3.0 with updated kernel 21-15 EL.
Please help me with this type of error. have you installed domino 652 on ES 3.0?
thanks
Ahh, now that you’ve posted the exact error message I see the problem. If you check the release notes I think you’ll find the requirements to install the compat RPMs - compat-libstdc++ and so-on. That should do it.
thanks, but where can i get that patch?
it’s not a patch, it’s an optional package (but apparently only an option in) redhead
