Problem displaying inlime mime images
hello all,
there’s a problem on one of my clients (6.5.2). he receives a message from an aol-client with inline jpgs. the message is about 2.5mbs large, but when you open it you neither see an image nor an attachment, although there are 5 $file-fields (size 48b ??) and a large amount of body fields. I found a knowledge-base-article describing a similar problem being fixed in 6.5.4 and installed the new client (which didn’t help).
If you open the mailfile using a webbrowser, everything is displayed correctly. you can get your notes client to display the images if you copy the mail into a new memo.
the question to answer is: why can´t the notes client display the images correctly??
any help would be appreciated…
tia
wolfgang
