Problem connection Notes to Oracle
Hi
My problem is that I must connect Notes server to Oracle database using an agent. On the server I create a DSN. In my agent I use this DSN and I receive this error message :
LS:DO could not complete requested operation
On my server I have a software to test my connection to Oracle and with it, my connection work great. Do you know what is the problem ?
Subject: Try this example…
Print “Running agent name”
Dim s As New NotesSession
Dim db As NotesDatabase
Dim view As NotesView
Dim doc, doc1 As NotesDocument
Dim item1, item2 As NotesItem
'Collect new Oracle data
Dim LCsession As New LCSession
Dim connect As New LCConnection("system data source name")
Dim fldLst As New LCFieldList
Dim fld As LCField
Dim strServer As String, strUserName As String, strPassword As String
Dim count As Long
Dim x As Integer
LCsession.ClearStatus
connect.Server = "server.name"
connect.Userid = "userid"
connect.Password = "password"
connect.connect
If( connect.execute(|select EMPLOYEE, FIRST_NAME, MIDDLE_NAME, LAST_NAME, DEPARTMENT
from LAWSON.PAF_EMPLOYEE_Active;|, fldLst) = 0) Then
Msgbox "Oops!"
Else
Msgbox "Worked"
connect.disconnect
Subject: Problem connection Notes to Oracle
Do you have the Oracle client installed on the Domino server? Do you have tnsnames.ora file on the Domino server? Does your DNS reference exist within the tnsnames.ora file?
Those would be the three things I would check first.
Subject: Good points … tnsnames.ora ; )
I’ve banged my head against the wall at least twice just because someone changed a server on me, and I had not updated that tnsnames.ora file to reflect the change.
Good point.
Jason
Subject: Example - connection
Option PublicUselsx “*lsxlc”
Dim v As NotesView
Dim docdel As NotesDocument
Set db = s.CurrentDatabase
'Declare Oracle variables
Dim connect As New LCConnection("System Data Source Name")
Dim fld As LCField
Dim count As Long
Dim x As Integer
Dim empnum As Variant
Set empnum = doc.num(0)
connect.Server = "server name"
connect.Password = "userpassword"
connect.connect
If( connect.execute(|select EMPLOYEE from LAWSON.EXEMPT_EMP where EMPLOYEE = empnum;|, fldLst) = 0) Then
	Msgbox "Oops!"
	End
Else
	Msgbox "Worked"
connect.disconnect
Subject: RE: Example - connection
I try this but on this line, i receive an error message like : Object variable not set
Dim connect As New LCConnection(“Oracle”)
In my case I use:Dim SiebelCon As New LCConnection(“oracle8”)
We are using LEI 6 on the particular Domino server that runs the code above.
We had to install another driver to work with SAP, and the statement changed to the below for agents calling BAPI’s (like stored procedures) from that system.
Dim SAPCon As New LCConnection(“sap”)
Hope this helps.
Jason
change the Oracle to your System Data Source name.
I try to use my DSN name but no result, only the same error message. My server is Domino 5.10
Just make sure that when you run the agent, it is running “on” the server. Lots of times people run tests and say it works great, but it’s not running on the server, and the problem is that the connection has not been tested on the server. This is probably not the case here, but just double-check.
Other than that, please post your code and show us the line of code that throws the error.
Jason
