Private view Corrupted. How to fix this problem
Dear ReaderPrivate view Corrupted. How to fix this problem ?
Subject: Private view Corrupted. How to fix this problem
Hi,This happens to our users all the time.
They say they ‘cannot see the documents in the view’.
Best option I have found is go to the users PC, click on the relevant view, do Actions - View Options - Remove view.
Exit the db (possibly exit note also), go back in, and click on the view. Notes assumes that users hasn’t rebuilt the view, so builds a new Private view for them. Assuming you mean the same thing…
fyi…my problem with these view’s - promised to be fixed in Notes 5. Not done. Then notes 6. Still not done. Notes 6.53, still not fixed. No doubt it will not be fixed in Notes 7 either.
Subject: RE: Private view Corrupted. How to fix this problem
When user have a lot private view. If some private view corrupted, how to restore it. Is private view stored in desktop6.ndk ?
Dear poster,
Can you be more specific? Any error messages?
You can remove the icon and readd it.
JYR
For faster answers, be C R I S P Y
Sorry. Just someone ask me this question.
