Print problem
hi Iam having problem with printing a form
In Notes client It does not print what it displays
i.e in display it looks good but when I print the text in the right margin does not print
I have a table with image inserted in it right portion of the images does not print .
why does it not print what it shows is this a bug?
thx in advance
Subject: print problem
Have you checked the ‘hide paragraph when …’ on the image (in desgner), and made sure ‘Printed’ isn’t selected.
Subject: RE: print problem
if the image is more than 800 pixels iam having the problembut display is OK but not print
