Print labels using data from NAB
I am a newbie to Lotus Notes, but I have experience in VBA programming.
I need to find a simple way to print labels in MS Word with the names and addresses of persons found in a Notes Address Book.
Is there a tool or some sample code that I can use to help me achieve this?
Subject: Print labels using data from NAB
This might help? It’s a bit old – I originally did this stuff in Notes 4.x – but the principles and code snippets are the same. One of the templates I use in the export / mailmerge code is a labels one:
HTH
Hello Wayne,
We have a product called “SWING InOffice” that you can try. It creates mailing labels using MS Word templates and Notes data. The transfer of data is done through predefined templates that you will set up with the help of the product. InOffice does not require any programming nor modifications to your existing Notes databases.
Besides the NAB, our product can work with any Notes database.
Take a look at: http://www.swingsoftware.com
Sinisa Bilandzic
sinisa.bilandzic@swingsoftware.com
