how do i get rid of the preferences and logout button from the domino web access template? Where are they hidden?
Subject: preferences and help
See this for more info on DWA customization:http://www.redbooks.ibm.com/abstracts/redp4188.html?Open
The Logout button can be disabled by either editing skin files that reference the Logout skin component and removing the tag that references it or editing the Logout_SkinComponent subform and removing all the content in the subform and saving it.
Most DWA design elements reside within the DWA Forms file which is located off the \iNotes directory.
