Post2° - web form not well formatted - question
Hello I post newly my question because I’ve not still found answer…
I’m working to a domino web application.
In my forms I call in HTML Head Content my stylesheet that is :“”
and in the fields properties (in the last tab) I put the class. At the same time for text style I use: Date:
well…
now, the problem is that when I call my form for the first time (so it has not been stiil saved) styles are ok.
but when i open the saved document styles are lose.
But the Html source code contains all styles recall.
Why this??
thankU in advance
Subject: Post2° - web form not well formatted - question
The path to your stylesheet is no good. It will work for form creation because that’s at one level:
http://SERVER/PATH/FormName?OpenForm
… it won’t work for a document, because that’s one level further down:
http://SERVER/PATH/View/DocID?OpenDocument
Re-state your stylesheet link properly, and you should be set. For example, you could use:
<LINK rel="stylesheet" type="text/css" href="/<Computed Value>/InStyle.css?OpenPage"
… where computed value = @WebDbName or somesuch.
HTH
