Post upgrade from Sametime 11.0 on CentOS 7 to Sametime 11.0 FP2, found that the stmeetingserver process was running at 100%. Reviewing the meetingserver.ini file I found that it was missing. I copied in the meetingserver.ini from backup and found that when the stmeetingserver process started the meetingserver.ini file would get removed.
Any subsequent starts yielded the same result with the stmeetingserver process running at 100%.
Setup a clean install of a Sametime server and before booting that server copied the meetingserver.ini. Revised on failed server to reflect the server name for the Node ( all path names were the same ) and started up the server. stmeetingserver now starts along with all the other processes.
I have attached this copy of the meetingserver.ini for reference. Keep in mind this version uses Domino 11.0.1 so you may need to adjust the /opt/hcl/domino/notes/11000100 to /opt/hcl/domino/notes/11000000 if your server is still running 11.0.0.
meetingserver.ini-linuxPostFP2upgrade.txt
@Reid Canavan
The .ini that you provided unfortunately will not help resolve the issue here
stmeetings is in a docker container that should be run in a separate machine
this issue is best handled in a case with the sametime support team
Please run the stdiagzip.sh utility on the community server
then open a case with support and upload the zip file which was generated when you ran the utility
from the data collected we will get more information that we will then be able to assist you further.
Hi Daniel,
We opened a case (CS0148705) with support but they were not able to assist us with the issue at hand. As such, I had to create a clean linux installation of the instance and from there grabbed the meetingserver.ini file ( CentOS 7, Domino 11.0.1, Sametime 11.0 FP2 ).
Only adjustment made was related to the NodeName parameter found at the end of the meetingserver.ini file to reflect the actual server it was being used against.
After doing this, our Sametime server came back up without issue.
I ran into the meetingserver.ini going missing before and felt that it would be helpful to others who may have this version of Sametime to use for reference.
