Hi all,
I developed a database using 6.5.1 client in which I have a form with a Reader field. This reader field contains the name associated with a particular ID file that I used to develop the database. I now wanted to try to use the database under R5 so I saved the database to a new copy and specified an NS5 extension. I took this database to another computer that only has an R5 client and sure enough, I was able to open the database.
However, using the exact same ID file that I used to create the database (and populate the reader fields), I no longer see the documents where the reader fields were populated - only those where the reader fields are left blank are available for me to see. Note that prior to making the copy to R5 format, I made sure that the “Enforce a consistent Access Control list” checkbox was checked.
Is there a bug with reader fields when “compacting” from R6.x to R5 format using NS5 file extension? Does anyone have similar experience or care to try to confirm?
Thanks,
Cesar
Subject: RE: Possible bug with Reader fields when converting R6 format to R5
First, there’s no guarantee that you will be able to use a database developed in ND6 from an R5 client at all.
I think the problem you’re having, has to do with how consistent access control is implemented. Certain information which helps to determine what you have access to is stored in your “desktop” file. If you file-copy the database to a new system, you’re not copying the desktop information, since it is stored in a different file. Hence, your access to the local documents is not established until you replicate with a server which pushes down the identity information about your roles and groups in the database, into your desktop information about the local replica.
I’m a little surprised that it didn’t recognize you if your username is in the readers fields, however. I wonder whether perhaps it’s not in canonical form (CN=…)?
Andre,
Thanks very much for your time to reply.
I am aware that there are certain features in R6 which cannot be used on an R5 client. I specifically used R5-only features even though working in R6 designer. So, in that sense, I would expect that the database should work and in fact, it does apart from the Reader fields not working.
I also went back to the R6 client where the database was developed and although I was sure of it, I checked and the names are, in fact, in Canonical format. It also follows that when I open the same database using the R6 client, the missing documents are now visible - proving the point that the documents are in the database but not visible to my ID using the R5 client.
It’s a mystery…
