!Plz help.Will it possible to pop up Excel Sheet from a "Web Client" to click on a button
Hi, For R5 Web Client
I have written an agent by which i m creating a chart in Excel Sheet .this agent i m running under a click of a button. but once i click this button this Excel sheet always open on “Server” not at my client machien. I m using a web Browser. On notes client it does’t give any prob. always open at my client machien but on web browser it was’t open at my client machien only on Server we can see their is a Excel visible. I want to open this Excel sheet on client machien by which who will click the button can see that excel file.
Well i do not know any way to do the same.
Please help me to overcome this prob…
Thanks in advance
Mudit Sharma
Subject: !!!Plz help.Will it possible to pop up Excel Sheet from a “Web Client” to click on a button
Today I deployed this one across a half dozen databases:Export view to Excel from Domino Web using LotusScript
It works great!
If you still want to use your own code, post it here so we can look it over.
Subject: RE: !!!Plz help.Will it possible to pop up Excel Sheet from a “Web Client” to click on a button
Hi here is my code kindly goo through. actully i m getting docs fro a view and filtering also creating an Excel file and putting all data into worksheet one. this worksheet will be the input for my chart. but it was’t works ones i use this code on a web browser As this file always displayed on the server not at my client machine.
Dim db As NotesDatabase
Dim listdoc As NotesDocument
Dim filterdoc As NotesDocument
Set maildoc = New notesdocument(db)
Const NotesMacro$ = "@Left(ex;"":"")"
Dim docview As NotesView
Dim dataview As NotesView
Set docview = db.getview("WeeklyStatusReport")  'get selected view
Dim entryOne As NotesViewEntry
Dim entryTwo As NotesViewEntry
Dim vc As NotesViewEntryCollection
Dim vc1 As NotesViewEntryCollection
Set vc1 = docview.AllEntries
fname="Deptwise Graphical Report"+".xls"
y(1)= "January"
y(2)="February"
y(3)="March"
y(4)="April"
y(5)="May"
y(6)="June"
y(7)="July"
y(8)="August."
y(9)="September."
y(10)="October"
y(11)="November"
y(12)="December"
Dim xlApp As Variant
Dim xlsheet As Variant
Set xlApp = CreateObject("Excel.application")
Set objEWrk=xlApp.Workbooks.add
Set xlsheet = xlApp.Workbooks(1).Worksheets(1)
xlsheet.Cells(1,2).Value= "January"
xlsheet.Cells(1,3).Value= "February"
xlsheet.Cells(1,4).Value= "March"
xlsheet.Cells(1,5).Value= "April"
xlsheet.Cells(1,6).Value= "May"
xlsheet.Cells(1,7).Value= "June"
xlsheet.Cells(1,8).Value= "July"
xlsheet.Cells(1,9).Value= "August"
xlsheet.Cells(1,10).Value= "September"
xlsheet.Cells(1,11).Value= "October"
xlsheet.Cells(1,12).Value= "November"
xlsheet.Cells(1,13).Value= "December"
Site(1)="Central Dropship"
Site(2)="CERQUAD Assembly"
Site(3)="Die Cage"
Site(4)=" End line"
Site(5)="ESH"
Site(6)="Facilities"
Site(7)="Flip Chip Assembly"
Site(8)="Hermatic Assembly"
Site(9)="HR"
Site(10)="IT/CIM"
Site(11)="KESM"
Site(12)="Test"
Site(13)="KTM TBE"
Site(14)="Learning Center"
Site(15)="Metal Finishing"
Site(16)="Metology Lab"
Site(17)="NPI"
Site(18)="PA LAB/Reliability"
xlsheet.Cells(2,1).Value= "Central Dropship"
xlsheet.Cells(3,1).Value= "CERQUAD Assembly"
xlsheet.Cells(4,1).Value= "Die Cage"
xlsheet.Cells(5,1).Value= " End line"
xlsheet.Cells(6,1).Value= "ESH"
xlsheet.Cells(7,1).Value= "Facilities"
xlsheet.Cells(8,1).Value= "Flip Chip Assembly"
xlsheet.Cells(9,1).Value= "Hermatic Assembly"
xlsheet.Cells(10,1).Value= "HR"
xlsheet.Cells(11,1).Value= "IT/CIM"
xlsheet.Cells(12,1).Value= "KESM"
xlsheet.Cells(13,1).Value= "Test"
xlsheet.Cells(14,1).Value= "KTM TBE"
xlsheet.Cells(15,1).Value= "Learning Center"
xlsheet.Cells(16,1).Value= "Metal Finishing"
xlsheet.Cells(17,1).Value= "Metology Lab"
xlsheet.Cells(18,1).Value= "NPI"
xlsheet.Cells(19,1).Value= "PA LAB/Reliability"
Row=2
For i=1 To 18
	x1=0
	x2=0
	x3=0
	x4=0
	x5=0
	x6=0
	x7=0
	x8=0
	x9=0
	x10=0
	x11=0
	x12=0
	Set entryTwo = vc1.GetFirstEntry()
	CntDefect2=vc1.count
	'While Not filterdoc Is Nothing
	For jg=1 To CntDefect2
		Set filterdoc= entryTwo.Document
		ddate=filterdoc.createdMonth(0)
		If  ddate=y(1) Then
			If filterdoc.dept(0)=Site(i) Then
				x1=x1+1
		If  ddate=y(2) Then
				x2=x2+1
		If  ddate=y(3) Then
				x3=x3+1
		If  ddate=y(4) Then
				x4=x4+1
		If  ddate=y(5) Then
				x5=x5+1
		If  ddate=y(6) Then
				x6=x6+1
		If  ddate=y(7) Then
				x7=x7+1
		If  ddate=y(8) Then
				x8=x8+1
		If  ddate=y(9) Then
				x9=x9+1
		If  ddate=y(10) Then
				x10=x10+1
		If  ddate=y(11) Then
				x11=x11+1
		If  ddate=y(12) Then
				x12=x12+1
		Set entryTwo = vc1.GetNextEntry(entryTwo)
	Next
	xlsheet.Cells(Row,2).Value= x1
	xlsheet.Cells(Row,3).Value= x2
	xlsheet.Cells(Row,4).Value= x3
	xlsheet.Cells(Row,5).Value= x4
	xlsheet.Cells(Row,6).Value= x5
	xlsheet.Cells(Row,7).Value= x6
	xlsheet.Cells(Row,8).Value= x7
	xlsheet.Cells(Row,9).Value= x8
	xlsheet.Cells(Row,10).Value= x9
	xlsheet.Cells(Row,11).Value= x10
	xlsheet.Cells(Row,12).Value= x11
	xlsheet.Cells(Row,13).Value= x12
	Row=Row+1
Next
jj=1
jj=1
chartchoice=21
XlApp.Charts.Add
Dim tchart As Variant
Set tchart = XlApp.Charts("Chart1")
'tchart.ChartType = chartchoice
'Type Name ="Line - Column"
'tchart.ApplyCustomType=True
tchart.SetSourceData(xlSheet.Range("A1:M19")), jj
'tchart.SetSourceData(xlSheet.Range("A1:M19")
'tchart.PlotBy=xlColumns
'tchart.Axes(xlSheet).Gridlines.Select
'tchart.PlotBy = xlRows
With tchart
	'.PlotArea.Select
	.HasDataTable = True
	.DataTable.ShowLegendKey = True
	.HasTitle = True
	.ChartTitle.Characters.Text = Ucase(charttitle) & Chr$(10)  & Cstr(Today)
	.HasLegend = True
	'.Axes(xlValue).MajorGridlines.Select
	'.PlotBy = xlRows
'If(chartchoice=51) Then
	'.ApplyDataLabels
End With
xlapp.visible=True
