Please Help me over a configuration fundamental
Sorry Forum if I sound perverse. But I’m new to Domino and I seem to be finding the stuff nobody thought mattered enough to put in the books.
I have my first server ready to configure. The configuration I want to achieve is for an internet mail server, a web server and a directory server on the same machine.
WHY when I go to Domino Administrator to begin server configuration (as the books tell me to do) does it make me set up the Notes client BEFORE the server has any configuration??? Surely any configuration on the client SHOULD BE SUBORDINATE to the server configuration and come AFTER the server is configured. No?
So when I begin to configure the client (as the Administration client makes me do first) and it asks me to enter my mail server details and domain name details etc what should I do? Give the info I intend to give the server afterwards (like pop.domino.mydomain.com … etc)?. Surely it’s an odd sequence to put this on the client before its on the server.
Or should I I just give the client some vanilla details (say pop.mail.yahoo.com … etc) to get past the client configuration and get onto the server configuration. If I do this, what happens to that bogus client setup information? Does it stay on the client or does it migrate onto the user document on the server?
Here’s the nub of it: I have found that if I enter the details in the client that I intend later to enter into the server (say pop.domino.mydomain.com … etc) then, when I get to the server configuration, I find TWO IDENTICAL Domino directories have been created and they are both waiting for me to configure them. Why two? Why two IDENTICAL ones? I cant edit their names and I can’t delete the duplicate.
If I go the other route and stick bogus yahoo stuff in the client just to get past it so I can configure the server then, when at last I get to the server, I only have ONE Domino Directory to configure … just like the book says.
Having worked that out I ought to feel great (Its only taken two days of experimentation!) except for the fact I still don’t understand anything. Please … What is going on?
Subject: Please Help me over a configuration fundamental.
Although some of the documentation might tell you to use the Admin client to register your servers, this doesn’t apply to your first server. You can’t do so with your first server since - as you point out - you haven’t got a server ready to contact yet and the the Admin client needs one.
When you installed your Notes client, did you also pick the Remote Server Setup Utility from the list of options? If not run setup again and make sure you install this.
On your Linux box run the /server -listen task (eg /lotus/bin/server -listen -I’m not sure what it installs to by default on Suse)
You can then launch the Remote Setup Utility on your workstation and specify the IP Address of your server to connect to. This will then allow you to setup the server. Once this is done you can set up your admin client and register the additional servers. By default whichever user you setup first will have its mail on the first server you setup.
Subject: RE: Please Help me over a configuration fundamental.
Phil thanks for this help. It makes sense to treat the first server differently. Could I impose a second a question on you?
The procedure I followed was the one you suggest up to the last step. After installing on SuSE, I used remote setup & server -listen to set up the first server. And then I tried to use the Administrator to configure it. (But because remote setup didnt let me create the Mail server with associated detail the Administrator issues arose).
Should I instead use a procedure like this:
  1. Install to SuSE
  2. Use remote setup to set up first server
  3. Use remote setup to set up Mail server
  4. Use Administrator to configure.
Thanks indeed
Mello
Just to clarify…when you setup your first server you are creating a new domain from scratch, so the remote server setup tool helps you do this. The first thing it asks is whether this server is the first server in the domain or a new server to go in your existing domain.
When you setup any further servers you are adding them to the existing domain, so you are expected to provide the necessary information to do this. So the steps are as follows;
FIRST SERVER
  1. Install OS and Domino Program
  2. run /server -listen
  3. Use Remote Setup Tool to configure first server
  4. Set up Domino Adminstrator to connect to your new server and complete any further config + ongoing admin.
ADDITIONAL SERVER(S)
  3. Use Domino Administrator to register the new server.
  4. Use Remote Setup tool to connect to server and run thru config to get the server up and running
  5. Use Domino Administrator to administer the server after completing 4)
Hope that helps.
Thanks Phil,Its the most suscinct outline of the steps I’ve seen!
Dunno though. I think there’s something wrong in the integration between the initial setup program for the linux version (your step 3 on the first server) and the Windows Administrator program. When it is first run, the Administrator Program requires some things to have happened in step 3 that haven’t. For example the setup program makes no provision for giving the pop and smtp server names but these are mandatory fields required by the Administrator program when it is run for the first time. Catch 22.
Anyway I’ll take some lunch with your outline and ponder longer.
Many thanks. I appreciate your help.
Mello
