Please Help: Display and Open Attachments or links
Hello,
I have been trying to display the contents of my profile document into a frameset like a home page.
How do I do it?
I have 2 forms:
Form1 - which is a PROFILE form with 1 editable richtext
          field (let's call it RTF1)
Form2 - which is a usual form with 1 computed richtext field
          (let's call it RTF2)
I use profile document to let user type-in anything and/or attach anything in RTF1 of Form1. RTF2 of Form2 on the other hand, is being used to display whatever information I have in Form1.
I am using a frameset and uses the named element form to display the information.
MY ISSUE:
I am able to see whatever I have in my profile form. However, for example with attachment, if i click on it, it says “Note Item not Found”. My document link won’t also work.
Can somebody please shed some light? What do I need to do to fix it. I have search the forum and it always mention web. But I am not using the web. Please advise.
I am using LotusScript as well as formula language on my development.
Thank you for your help.
Subject: Please Help: Display and Open Attachments or links
Is it possible to just do away with the profile document altogether? Have a regular form to enter the information and then use a dblookup to retrieve the form in read mode using the username to display in the frameset?
Subject: RE: Please Help: Display and Open Attachments or links
It seem that I have no choice but to use usual form than profile form. For some reason, there seem to be a limit in profile form. It let’s you attach and save multiple documents in a RichText field. But when you close the profile document, the attachment is somehow being corrupted. And, only the last attached document is being recognized.
