Below is a section of code I copied from the Help file under “Examples: AppendTable method”. I though that I could create a form, add a button and place the code section, open the form in Lotus Note, and click the button – then I’d see a table on the form. The actual result is that the form showed nothing. I traced through the code, not error was generated at any line. I believe that I missed something very simple and very important.
- This view action creates a basic auto-width table of 4 rows and 3 columns, and populates it.
Sub Click(Source As Button)
Dim db As NotesDatabase
REM Create document with Body rich text item
Dim doc As New NotesDocument(db)
Call doc.ReplaceItemValue(“Form”, “Main topic”)
Call doc.ReplaceItemValue(“Subject”, “Table 4 x 3”)
Dim body As New NotesRichTextItem(doc, “Body”)
REM Create table in Body item
rowCount% = 4
columnCount% = 3
Call body.AppendTable(rowCount%, columnCount%)
REM Populate table
Dim rtnav As NotesRichTextNavigator
Set rtnav = body.CreateNavigator
Call rtnav.FindFirstElement(RTELEM_TYPE_TABLECELL)
For iRow% = 1 To 4 Step 1
For iColumn% = 1 To 3 Step 1
Call body.BeginInsert(rtnav)
Call body.AppendText("Row " & iRow% & ", Column " & iColumn%)
Call body.EndInsert
Call rtnav.FindNextElement(RTELEM_TYPE_TABLECELL)
Next
Next
REM Save document and refresh view
Call doc.Save(True, False)
Call ws.ViewRefresh
