Hello,
Does anyone have experience with phasing out ecm/ccm from connections 6.5 Cr1?
We have migrated all of our library's to Files in Connections. So we can phase out ecm/ccm.
I you have any tips & tricks where to think off, please let me know.
Thanks and regards,
Paul Welbroek.
Hi
Third-party vendors supply tools and the associated support for migration from Connections Content Manager (CCM) to HCL Connections Files.
ISW is one such vendor, and further details about their offering, Huddo CCM Migrator, can be found in the documentation below:
https://www.huddo.com/ccm-migrator
referrence:
Hope this helps.
regards,
Ariel
Hi
Depends on how you're gonna phase out. You could start with disabling the search integration and after a while you remove the widget
Or you just do a side by side migration to Connections 8 and get rid of all the ccm stuff and still could go back to the old environment in case something is missing.
