PDF conversion failed after installation HCL Connections 8 CR14
After installing CR14 I received the information that the conversion of Wikis, Forum entries or Blogs is no longer working.During a remote session with HCL Support ( thx a lot to Ale !! ) we could find the cause and we also could solve it.It seems that the installation changed some setting in the custom properties for IC360 – it was set to “wasadmin” what caused the PDF conversion to stop working.
This is a companion discussion topic for the original entry at https://brandlrainer.info/2026/07/07/pdf-conversion-failed-after-installation-hcl-connections-8-cr14/
