Outline entry label too long, I need 2 lines
Hi,I have a problem and I hope the solution is simple. I have a outline entry label that is too long, that makes my navigator(page in a frameset) too large. As far as I use only Lotus client to display it, I need the entry label to be written in 2 lines. I haven’t been able to find how.
Thanks in advance for your help.
Subject: Outline entry label too long, I need 2 lines
In the Outline Entry properties there is a space below the label for entering popup text. If you enter the text you want in there it won’t scroll onto two lines as you wish/request but it will display the entire text on one line when you mouse over the entry - if the window is not wide enough to display the entire label.
hth
