Out of Office Schedule Problem
Server has recently been upgraded to version 6 and have always had the Agent Manager in the Server document set to run every 60 minutes. I have noticed recently that a very small amount of users who set the Out of Office agent are running every 360 minutes (6 hours) instead of every 60 minutes.
I have gone into the OoO agent on the users mail files via designer and changed manually back to 60 minutes but the next day they are back to 6 hours again. Something is changing them back overnight.
Can anyone tell me where else I can look. I always thought it was just the Agent Manager info on the server document but maybe on Notes 6 there is extra configs?
Subject: Out of Office Schedule Problem
Alison,
There are potentially two factors that are not helping you with this issue:
Mail Template - For each Database there will be a template it was created from. A setting for OOO is in the template as well.
Design Task - I am guessing you are running this each night (the default setting), this is more than likley causing the rollback you are experiencing
Suggestions:
Either stop the design task to test perhaps one night, then look into a more permanent solution or update the template with your 60 minute setting.
Regards Gary
Alison,
Suggestions:
Regards Gary
Subject: RE: Out of Office Schedule Problem
I would do what Gary suggested and change the template. You can also run design task from the server console command any time you want, so you don’t have to hang around during the night :slight_smile:
