Have an app based on MS Office Library, in the main form (with MS Word embedded object) → querysave event → keep validation code :
If note.IsNewNote And note.txtClassifiers(0) = “” Then
DataOK=False
Do While note.txtClassifiers(0)="" Or DataOK=False
Messagebox "You must enter a classifier"
DataOK= wks.DialogBox("frmClassifiers", True, True, False, True, False, False, "Classifiers",,True)
Loop
no problem generating one (1) doc, but, when i add a new one and the code calls the dialogbox method got the panic error.
I have tested this in another database and same result (guessing the nsf file was corrupt).
All post found about this error are about server crashes but no one about notes client crashing, the database is a local one.
Thanks in advance
Leo
