Open View Problem
I have got one application which is developed in .net technology. In this application we have got a screen for adding evidence against a subsystem and this evidence can be of any type.
Here lotus notes documents are of one evidence type and lotus notes documents are of any type, say it can be View Link,Doc Link and DB Link. Normally how users are doing is they will select one document(mail) and after that Edit menu + copy as Link and select any link type say View Link,Doc Link and DB Link. Once they attached the lotus notes evidenece we are giving options for user to open the attached lotus notes links. For opening the lotus notes view link, we are using the below mentioned programming. But while opening I am getting the following error message.
public function openLotusView(serverid,dbfile,viewName)
msgbox viewName
on error resume next
Dim strError
Set ws = CreateObject("Notes.NotesUIWorkspace")
if err.number > 0 then
	strError=err.Description
	openLotusView=strError
	err.Clear
	exit function
end if
Call ws.OpenDatabase( serverid, dbfile, "","", False,True )
	err.Clear
	exit function
end if
if viewName <> "NA" then
	set mydb=ws.CurrentDatabase
	call mydb.openview( viewName )
	msgbox viewName
end if
	err.Clear
	exit function
end if
end function
Error Message:View or Navigator “<>” does not exist. Here <> will be replaced with the corresponding view name.
Can you please let me know why I am getting this error message and tell me a solution for this.
Thanking you.
Girish Kumar.V
Subject: Open View Problem
Have you debugged this? Do you know which line is causing the error?
The Notes 6 Designer Help for the CurrentDatabase property of the NotesUIWorkspace states:
“The GetCurrentDatabase method supersedes this property due to the failure of the property when the user accesses the current database through View - GoTo (for example, on the workspace menu with the database selected).”
Perhaps try that method instead.
Subject: RE: Open View Problem
“Open View” method is causing the error. I tried with the method that you mentioned, but still I am getting the same error.
My intention is to open the particular view that the user is passed from the corresponding database. Before open the view I created workspce object, then I open the current database using ws.currentdatabse method. While opening I was getting that error. Please suggest me a good method for opening a view.
Girish Kumar.V
