Object variable not set using 6.0, works in 6.5
Hi, in the switcher Mail form I of the mail6ex.ntf template i modified it and added a field that basically displays the size of the database. The code is as follows:
Sub Onload(Source As Notesuidocument)
Dim db As NotesDatabase
Dim doc As NotesDocument
Dim uidoc As notesuidocument
Dim used As Double
Dim empty As Double
Dim size As Double
Dim emptymem As Double
Set uidoc = ws.Currentdocument
Set doc = uidoc.document
size = db.Size
size  = Round(size / 1000000,0)
used = db.PercentUsed
empty = 100 - used
emptymem = Round(empty/100 * size,2)
size = Round(size - emptymem,2)
doc.ds = Cstr(size) & " MB"
If size > 499 Then
	doc.d3 = "Cleanup Mail"
Else
	doc.d3 = ""
It works in 6.5 + but in the 6.0 client when you open the db I get an Object variable not set on this line:
I tried other events but say thing all the time.
I also have a ‘refresh’ button with the exact same code on the form, and it works on both 6.0 6.5. Its just when opening the database in 6.0 that it gives me the Object Variable Not Set message.
My guess is it just doesn’t work in 6.0, but if anyone can offer and help it would be much appreciated.
ST
Subject: Possible workaround Try:
Set uidoc = Source	Set doc = Source.Document
Subject: RE: Possible workaround Try:
Thank-you Bill. It worked. Can you explain to me why? Whats special about using
Set uidoc = Source
instead of
ST
As I understand it, this event fires before the uidocument object actually becomes the CurrentDocument in the workspace. Source, on the other hand, already comes with a free handle, so timing isn’t an issue.
