Hello,
We are currently experiencing problems with a view.
The view uses custom icon’s instead of the standart notes numbered icons.
(Display values as icons; icon used “PL_Blue.gif”/20x18pixels/16colors/103bytes)
Now, if there are too many icons shown in the view, the client will crash with NSD.
I’ve already countered the effect by collapsing all categories, decreasing the GIF size and amount of colors used.
This seems to help a bit, but when users expand the view, it will again result in a NSD (memory segments exceeded).
Suggestions anybody?
Thanks, AceIndy
Subject: NSD when using too many custom icons in a view
Hello,
Found any workaround ? I have got the same trouble ?
Thanxs
hcl-bot
3
Subject: RE: NSD when using too many custom icons in a view
Yes I did; Started working with color-columns and webdings font
It has a downside; it will 1/2 the amount of available columns, since you’ll need a color-column for every normal column
Have fun,
hcl-bot
4
I did too using color columns. And the result is great : http://emmakael.free.fr/pub/Icone.gif
Thxs for your answer
