Help me please. Domino 6.5.1, Windows 2003.
NSD error if i`m: “load router”
INFO (0): Using PSAPI DLL
search path: .;C:\WINDOWS
Host Name : SERVER
User Name : SYSTEM
Date : Tue Jan 25 08:43:38 2005
Windows Dir : C:\WINDOWS
Arguments : h:\domino5b2\nsd.exe -info -log “h:\domino5b2\data\IBM_TECHNICAL_SUPPORT\sysinfo_SERVER_2005_01_25@08_43_38.log”
OSVersion : Windows Server 2003 5.2 (Build 3790), PlatID=2, (2 Processors)
INFO (0): Using NSD profile C:\WINDOWS\notesnsd.ini
inst h:\domino5b2\data already added
INFO (0): Found 3 Notes processes, matched 3
INFO (0): Using NSD profile nsd.ini
→ Instance# 1 : (current)
Ini File : h:\domino5b2\notes.ini
Data Dir : h:\domino5b2\data
Prog Dir : h:\domino5b2
Notes Build: Release 6.5.1 January 21, 2004
Proc List:
h:\domino5b2\nservice.exe (2f50)
h:\domino5b2\nSERVER.EXE (3028)
h:\domino5b2\nevent.EXE (3140)
DBG(314c) 08:43:58
@@@@@@@@@@@@@@@@@ Process Table @@@@@@@@@@@@@@@@@
Active Users:
UID Name
0 SYSTEM
500 Administrator
INFO PID PPID UID STIME COMMAND
0000 0000 0 ??? []
0004 0000 0 ??? [ ?:0004]
01c0 0004 0 01/24 17:48:38 [ smss:01c0]
01f0 01c0 0 01/24 17:48:42 [ csrss:01f0]
0208 01c0 0 01/24 17:48:43 [winlogon:0208]
0234 0208 0 01/24 17:48:43 [services:0234]
02e8 0234 0 01/24 17:48:43 [ svchost:02e8]
0ae8 02e8 0 01/24 17:50:10 [ rsmsink:0ae8]
0c60 02e8 0 01/24 17:50:16 [wmiprvse:0c60]
031c 0234 0 01/24 17:48:44 [ svchost:031c]
0484 0234 0 01/24 17:49:00 [ svchost:0484]
04b4 0234 0 01/24 17:49:00 [ svchost:04b4]
04c0 0234 0 01/24 17:49:00 [ svchost:04c0]
2720 04c0 500 01/24 23:16:00 [ntbackup:2720]
06d4 0234 0 01/24 17:49:55 [ spoolsv:06d4]
06f4 0234 0 01/24 17:49:55 [ msdtc:06f4]
07d4 0234 0 01/24 17:49:57 [ ALERT:07d4]
07e0 0234 0 01/24 17:49:57 [ appmgr:07e0]
07f0 0234 0 01/24 17:49:57 [ Catirpc:07f0]
00c8 0234 0 01/24 17:49:57 [ cisvc:00c8]
1640 00c8 0 01/24 17:56:18 [cidaemon:1640]
1654 00c8 0 01/24 17:56:19 [cidaemon:1654]
00f0 0234 0 01/24 17:49:57 [ Dfssvc:00f0]
0124 0234 0 01/24 17:49:57 [ dns:0124]
0154 0234 0 01/24 17:49:57 [elementmgr:0154]
0174 0234 0 01/24 17:49:57 [ svchost:0174]
01d0 0234 0 01/24 17:49:57 [iGateway:01d0]
01dc 0234 0 01/24 17:49:57 [inetinfo:01dc]
009c 0234 0 01/24 17:49:57 [ ismserv:009c]
03bc 0234 0 01/24 17:49:57 [ kodweb:03bc]
0428 0234 0 01/24 17:49:58 [LogWatNT:0428]
04e0 0234 0 01/24 17:50:00 [ RunSC:04e0]
04dc 04e0 0 01/24 17:50:00 [ PCtl:04dc]
0840 04dc 0 01/24 17:50:01 [ BIL:0840]
0988 04dc 0 01/24 17:50:02 [CILRS232:0988]
0520 0234 0 01/24 17:50:00 [ ntfrs:0520]
064c 0234 0 01/24 17:50:01 [ svchost:064c]
0678 0234 0 01/24 17:50:01 [ snmp:0678]
06b4 0234 0 01/24 17:50:01 [srvcsurg:06b4]
0834 0234 0 01/24 17:50:01 [ wins:0834]
085c 0234 0 01/24 17:50:01 [WMServer:085c]
0870 0234 0 01/24 17:50:01 [ tcpsvcs:0870]
0890 0234 0 01/24 17:50:01 [ mqsvc:0890]
08b8 0234 0 01/24 17:50:02 [ RsServ:08b8]
08c4 0234 0 01/24 17:50:02 [ svchost:08c4]
2f4c 08c4 0 01/25 08:33:52 [ w3wp:2f4c]
0810 0234 0 01/24 17:50:53 [ alg:0810]
-> 2f50 0234 0 01/25 08:43:37 [nservice:2f50]
-> 3028 2f50 0 01/25 08:43:37 [ nSERVER:3028]
-> 3140 3028 0 01/25 08:43:43 [ nevent:3140]
0240 0208 0 01/24 17:48:43 [ lsass:0240]
0ec8 0b3c 500 01/24 17:51:14 [Explorer:0ec8]
06d8 0ec8 500 01/24 17:51:19 [StatusClient:06d8]
1010 0ec8 500 01/24 17:51:19 [ ctfmon:1010]
1024 0ec8 500 01/24 17:51:19 [ kodweb:1024]
23bc 0ec8 500 01/25 08:34:58 [ NOTEPAD:23bc]
1060 1004 500 01/24 17:51:24 [ javaw:1060]
1234 169c 500 01/24 18:49:43 [ setup:1234]
31f0 3114 0 01/25 08:43:38 [ nsd:31f0]
Num Processors : 2
CPU Type : 586
CPU Info: : Intel
CPU Level : 6
CPU Revision : 2058
CPU Mask : 3
Min App Addr : 10000
Max App Addr : 7ffeffff
Page Size : 4096
Allocation Gran.: 10000
DBG(314c) 08:43:58
@@@@@@@@@@@@@@@@@ h:\domino5b2\notes.ini @@@@@@@@@@@@@@@@@
-Skip-
Ethernet Stats:
Interface Statistics
Received Sent
Bytes 1917989278 3470744876
Unicast packets 17401940 16676487
Non-unicast packets 27507 6611
Discards 0 0
Errors 0 0
Unknown protocols 24070
Routing Tables:
IPv4 Route Table
Interface List
0x1 … MS TCP Loopback interface
0x10003 …00 0a 5e 01 97 be … 3Com 3C996B Gigabit Server NIC
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.1 10
0.0.0.0 0.0.0.0 192.168.1.5 192.168.1.1 10
10.20.0.0 255.255.0.0 192.168.1.5 192.168.1.1 1
62.0.0.0 255.0.0.0 192.168.1.5 192.168.1.1 1
65.0.0.0 255.0.0.0 192.168.1.5 192.168.1.1 1
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
192.168.1.0 255.255.255.0 192.168.1.1 192.168.1.1 10
192.168.1.1 255.255.255.255 127.0.0.1 127.0.0.1 10
192.168.1.255 255.255.255.255 192.168.1.1 192.168.1.1 10
194.0.0.0 255.0.0.0 192.168.1.5 192.168.1.1 1
195.0.0.0 255.0.0.0 192.168.1.5 192.168.1.1 1
197.0.0.0 255.0.0.0 192.168.1.5 192.168.1.1 1
224.0.0.0 240.0.0.0 192.168.1.1 192.168.1.1 10
255.255.255.255 255.255.255.255 192.168.1.1 192.168.1.1 1
Default Gateway: 192.168.1.1
Persistent Routes:
None
IPv6 Route Table
Interface List
4 …00 0a 5e 01 97 be … 3Com 3C996B Gigabit Server NIC
3 …00 0a 5e 01 … 6to4 Pseudo-Interface
2 …c0 a8 01 01 … Automatic Tunneling Pseudo-Interface
1 … Loopback Pseu do-Interface
Active Routes:
If Metric Network Destination Gateway
2 5 fe80::5efe:192.168.1.1/128
4 8 ff00::/8 On-link
4 4 fe80::20a:5eff:fe01:97be/128
1 4 ::1/128 ::1
1 8 ff00::/8 On-link
1 4 fe80::1/128 fe80::1
Persistent Routes:
None
Protocol Stats:
IPv4 Statistics
Packets Received = 17553455
Received Header Errors = 903
Received Address Errors = 1373
Datagrams Forwarded = 91097
Unknown Protocols Received = 0
Received Packets Discarded = 0
Received Packets Delivered = 17460082
Output Requests = 16730183
Routing Discards = 0
Discarded Output Packets = 0
Output Packet No Route = 0
Reassembly Required = 0
Reassembly Successful = 0
Reassembly Failures = 0
Datagrams Successfully Fragmented = 0
Datagrams Failing Fragmentation = 0
Fragments Created = 0
IPv6 Statistics
Packets Received = 324754
Received Header Errors = 0
Received Address Errors = 0
Datagrams Forwarded = 0
Received Packets Disc arded = 0
Received Packets Delivered = 0
Output Requests = 325277
Discarded Output Packets = 391
ICMPv4 Statistics
Received Sent
Messages 119972 92105
Errors 0 0
Destination Unreachable 224 577
Time Exceeded 903 903
Parameter Problems 0 0
Source Quenches 0 0
Redirects 114667 86534
Echos 2068 2023
Echo Replies 1947 2068
Timestamps 0 0
Timestamp Replies 0 0
Address Masks 0 0
Address Mask Replies 0 0
ICMPv6 Statistics
Received Sent
Messages 74 475
Errors 0 0
Destination Unreachable 74 74
MLD Reports 0 2
Router Solicitations 0 3
Neighbor Solicitations 0 396
TCP Statistics for IPv4
Active Opens = 2101
Passive Opens = 2759
Failed Connection Attempts = 132
Reset Connections = 342
Current Connections = 26
Segments Received = 17316324
Segments Sent = 16600414
Segments Retransmitted = 24433
TCP Statistics for IPv6
A ctive Opens = 477
Passive Opens = 477
Failed Connection Attempts = 0
Reset Connections = 1
Current Connections = 18
Segments Received = 324680
Segments Sent = 323731
Segments Retransmitted = 14
UDP Statistics for IPv4
Datagrams Received = 140949
No Ports = 579
Receive Errors = 0
Datagrams Sent = 13229
UDP Statistics for IPv6
Datagrams Received = 0
No Ports = 0
Receive Errors = 0
Datagrams Sent = 523
Started at: Tue Jan 25 08:43:38 2005
Ended at: Tue Jan 25 08:44:07 2005
Generated Messages:
Please send the following files:
NSD Log : h:\domino5b2\data\IBM_TECHNICAL_SUPPORT\sysinfo_SERVER_2005_01_25@08_43_38.log
