Has anyone else had issues with the READ method of the NotesStream class?
After using NotesXSLTransformer class, I’ve only been able to get the READTEXT method to work on the NotesStream output object… the READ method (with # chars parameter) would never work properly.
Or is it, if you pass a larger number of characters than the object has, it will return null? haven’t tested that actually, but that should not be the case by design, else that would be bad design.
