NotesSQL 3.02g ODBC Problem
Hello Notes people,
Just wondering if somebody can help me out. I have just installed NotesSql 3.02g on a PC for a user, I’m trying to add an ODBC entry under System (the problem also occurs for a user DSN) . When I select the NotesSQL driver from the list of available Data Sources, the Data Source Screen and ODBC Admin screen both close down with no error.
The PC is running Windows XP SP 1
Has anybody seen this before?
Many thanks, Ben
Subject: NotesSQL 3.02g ODBC Problem
yes, it is sp1
Subject: RE: NotesSQL 3.02g ODBC Problem
Is that really the problem? Unfortunately installing SP2 isn’t an option at the moment (hasn’t been tested with our SOE)
I’ve checked the eventlogs, it’s actually crashing with a Dr Watson error:
The application, C:\WINDOWS\system32\odbcad32.exe, generated an application error The error occurred on 04/19/2005 @ 11:21:31.197 The exception generated was c0000005 at address 0101E610 ()
It’s not a SP1 issue. I am running with WinXP Pro with SP2 and I have the same problem as described here. I’m running with Notes R6.5.4. I thought about changing the Microsoft Data Access Components version (to 2.8), but so far all attempts have failed.
Something weird to note. I was able to install the NotesSQL sample connector. It shows up in the System DSN list! But when I try to ‘Configure’ it, I get the same error.
Any help to get this working would be greatly appreciated!
I was able to fix this problem by verifying my Notes installation. I search my whole system for my notes.ini file. I search turn up two notes.ini files. One located in the C:\Windows and the other in C:\Lotus\Notes. The paths to these two were also declared in my PATH variable. Apparently, the notes.ini file was corrupted but it was still being read since it was within my ‘path’. I deleted the notes.ini file in the c:\windows directory.
Now everything works. Hope this helps everyone!
Your solution fixed my problem - thanks for posting it.
