NotesRichTextRange.FindAndReplace Problem and notesRichTextNavigator.FindNextElement
I am taking wysiwyg content (Formatted Rich Text that I allow Domino to render as HTML over the web) that is currently found in Notes documents and I am trying to replace rich text content with same text wrapped with tags that reference styles. I then plan on striping the text of all of its formatting that I can just pass the html through to the web. This code works perfectly fine in displaying the different paragraph text and the font size, color and whether it is bold yet when I do the find and replace the code stops working @ “Loop While rtnavPara.FindNextElement(RTELEM_TYPE_TEXTRUN)”. I get the error… “Position is not valid”. Does anyone know why or how to resolve this? I’ve tried resetting the position in the “NotesRichTextRange” but no luck. Can someone help out here?
Sub Click(Source As Button)
Dim db As NotesDatabase
Dim dc As NotesDocumentCollection
Dim doc As NotesDocument
Dim body As NotesRichTextItem
Dim objitem As NotesRichTextItem
Dim rtnavBody As NotesRichTextNavigator
Dim rtnavPara As NotesRichTextNavigator
Dim rtrangePara As NotesRichTextRange
Dim rtrangeRun As NotesRichTextRange
Dim paraCount As Integer
Dim runCount As Integer
Dim stylecolor As Integer
Dim stylesize As Integer
Dim stylebold As Integer
Dim style As NotesRichTextStyle
Set dc = db.UnprocessedDocuments
Set doc = dc.GetFirstDocument
Set body = doc.GetFirstItem("Body")
REM Get first paragraph in Body item
REM Set range and navigator for it
Set rtnavBody = body.CreateNavigator
If Not rtnavBody.FindFirstElement(RTELEM_TYPE_TEXTPARAGRAPH) Then
	Messagebox "Body item does not contain text,",, _
	"Error"
	Exit Sub
Set rtrangePara = body.CreateRange
Set rtrangeRun = body.CreateRange
Do
	paraCount = paraCount + 1
	runCount = 0
	Call rtrangePara.SetBegin(rtnavBody)
	Call rtrangePara.SetEnd(rtnavBody)
	Set rtnavPara = rtrangePara.Navigator
REM Get each run in paragraph
REM Display it
	Call rtnavPara.FindFirstElement(RTELEM_TYPE_TEXTRUN)
	Set style = rtrangePara.Style
	Do
		runCount = runCount + 1
		Call rtrangeRun.SetBegin(rtnavPara)
		stylecolor = style.NotesColor
		stylesize = style.FontSize
		stylebold = style.Bold
		Messagebox rtrangeRun.TextRun,, _
		"Paragraph " & paraCount & ", Run " & runCount
		Messagebox "Color: "+Cstr(stylecolor)+" Size: "+Cstr(stylesize)+" Bold: "+Cstr(stylebold),,"color"
		Dim para As String
		para = rtrangeRun.TextRun
		para = |<span class="rob">|+para+|</span>|
		flag = rtrangeRun.FindAndReplace( rtrangeRun.TextRun , para )
		' Call doc.save(False, True)
		' Call rtrangePara.SetEnd(rtrangeRun)
		' Call rtrangePara.Reset( True, True )
		' Call rtrangePara.SetBegin(rtnavBody)
		Call rtnavPara.SetPosition( 2 )
Loop While rtnavBody.FindNextElement(RTELEM_TYPE_TEXTPARAGRAPH)
