Notes on a stick Drive letter Issue
We are testing out the notes on a stick, and have tried standard and roaming users during the testing. Due to the USB drive letter being dynamic the notes.ini has to be changed manually prior to starting the application.
Does anyone have a solution to this???
Subject: Notes on a stick Drive letter Issue
Did you do a regular notes install on the stick? If so you shouldn’t have.
The install option for installing on a USB drive is a little different, to avoid the exact issue you are describing.
Full instructions on how to install on USB are in the release notes.
Also see this
http://www-1.ibm.com/support/docview.wss?rs=899&uid=swg21247232
