Notes Configuration Problem
Hi All, I need help to solve my minor problem ,I have configured the client many time but i have never faced this problem,
problem is , when i want to install the client in my system, it install successfully, but as i click the notes icon wich is show in desktop to cinfigure it with server, the IBM welcome screen comes and after that no screen comes to configure properly, what is the reason behind this, please give me quick response.
thanks & regards
zubair a khan
Subject: Notes Configuration Problem
Check if you have Windows OS permission to create/modify files in Notes installation directories/temp directories.
Regards
Litty Joseph
Subject: RE: Notes Configuration Problem
Hi Litty,
thanx for quick response, my problem have been shorted out, bcz i had found cause for that, there is not notes.ini file in data folder of notes so i had copy from another location and paste it in that data folde of notes. after that my notes give me gui to configure with domino.
thanx & regards
zubair a khan
