Nomad and DLeap on same machine
Domino v14 FP4
Nomad Web version 1.0.16
DLeap version 1.1.6
Has anyone experienced any issues with this scenario?
Specifically that Nomad is interfering somehow with login into Leap?
Everything was working fine in Leap bu we now get a 404 error. I have reinstalled but to no avail.
Problem/Query:
Domino Leap utilizes the Domino Web Engine (HTTP Server), while Nomad runs its own dedicated task called “Nomad”. Both operate independently on different default secure ports: the HTTP Server uses port 443, and the Nomad server uses port 9443.
Please check issuing the ‘show task only’ Domino server console command to know on which ports these tasks are listening.
Do you see any error message on the Domino server console when browser reports 404 ?
Also check logs here “/${DATA}/domino/workspace/logs” and see if it has any errors reported.
Thank you
Shrikant J
Thanks for the response. I did think they should not interfere with each other as my v12 server they run fine together. No obvious error messages however one thing of note is that this error occurs even before I am given the server log in screen. Tested by opening names.nsf and log in shows as expected.
Actually just tried the Verse connection on this server and get the same issue.
SO /verse and /volt give the same 404 not found or cannot read error.
Does anyone know where the Domino Leap area is?
I can then delete this and post in a more relevant area
Have a look at options in home. You may also modify your profile to incl Leap in that. Or use modify my products while in forums
Thanks but I cannot locate Domino Leap.
Is it dead?
Domino leap is very much alive. Essentially hcl leap and domino leap is the same thing and share the same source other than the fact that domino leap is specific to hcl domino. That must be the intention to have a forum for only hcl leap.
Have a look at
https://www.hcl-software.com/blog/domino/hcl-domino-leap-1-1-new-name-and-loaded-with-new-features
Hmm okay thanks we shall see.
The usual standard of HCL communication.
