Need Help with SSL
Hi,I’m trying to configure SSL, I had done all the steps in the Domino Admin Help.
when I start the server I found these messages :
HTTP server : Starting…
HTTP Server : SSL Error : Keyring File access error, key ring file [file_name.kyr], [Default Server]
SMTP Server Error: SSL Error : No local certificate
I can’t find the problem
Any help ?
regards
E.H.Y
Subject: Did you create a certificate?
Subject: RE: Did you create a certificate?
hi,What I had done :
  • Create a certification database
  • Create a keyring
  • I registred a Certification Authority (CA)
  • I sent a certificate request
  • I merged the certificate (from the CA) into my keyring file
  • I enabled SSL on HTTP and SMTP
And the result was the error messages !
So…this is my problem …
Regards
Subject: Need Help with SSL
There are already some posts on this:
https://www-10.lotus.com/ldd/nd6forum.nsf/Search?SearchView&Query="SSL%20Error%20%3A%20No%20local%20certificate"&SearchOrder=0&Start=1&Count=100
A user has found out something that my be interesting for you: https://www-10.lotus.com/ldd/nd6forum.nsf/55c38d716d632d9b8525689b005ba1c0/34b4c15b81253b1b85256cf000623690?OpenDocument
I for myself can’t help more, sorry
Subject: RE: Need Help with SSL
thanks any way Tom,But i had already seen what was posted about the subject.
I will try again
regards
Subject: Have you copied keyfile.kyr and keyfile.sth to the Domino data directory?
it always confuses me that you create the things on your pc, rather than the server.
Subject: The problem is with the OS !!!
Hi all,I had done many tests and I tried the same configuration on another PC with Windows 2000… curiously It run !!!
I think that the problem is with the autorisation given to the file keyfile.kyr
When (On Windows XP) I change this autorisation and give All total control … it run correctly ???
But there is another problem now … this autorisations are changed after few minutes and when I restart HTTP or SMTP I have again the error message !!!
Anyhelp please …
E.H.Y
