Need help with rich text field
I have two forms. One that contains contact information that is created and updated by an admin and another form tht contains specifcations on a particular contact (response from to the user info form). In the user info from I use DBLookups to get the info from the response document and show it on the user info page. The info shows up up correctly in most cases but One field is a rich text and this one seem to have some problems… When I modify the info in the response doc the changes take place on the form but they don’t translate to the main form with the DBLookup. It seem to keep the old info in cache even though I indicated to use noCache… any help towards a solution would be great! Bryce.
Subject: need help with rich text field…
Rich text retrieved by @DbLookup will only work as a Default formula for a field, so I think you are facing a basic limitation, if I understand your scenario correctly.
