Need help for unattended installation FP2
Hello,
need help for this theme. I try a installation with the Altiris Deployment Console. I get a sharde network drive, put at a folder the *.exe and make such order in the little script from altiris. at first a net use…for the network folder and this for *.exe file : T:\Lotus_notes\notes901fp2_win.exe -px -a /s /v" /qb+"
So if i will start this scribt at a pc, and a user without admin rights are login…nothing will happend. if i do the same…but the user had admin right…all will running without problem. at the altiris task for this…i say…make this job with admin rights and put the domain admin and pass inside there…but nothig change for the user without admin rights. no idea. someone can help…i don’t like the idea to install this fp2 with hands to many user
Subject: Attach / post script so we can review it please?
Subject: Argument string for silent install
Not familiar with Altiris Deployment Console, but here’s the argument string I’ve been passing to notes901fp2_win.exe for silent installs:
-s -a /s /v"/LV* /QN"
This update is installed after Notes 9.0.1 Social Edition by a wrapper script. With regard to administrator rights—unless you’re deploying to Windows XP or have configured Notes to avoid protected folders, I think you’ll need those elevated privileges.
