This is my first post. I’m trying to display a field containing HTML on the web using LotusScript. So far, I’m not having any luck. I’m probably just leaving out something simple. The field name I’m trying to display is VideoField. I don’t think I need to go to a view to get the infomation, as the field exists on the current document (would that be the UI document, or document.context?). Seems like this should be fairly easy, but I just can’t get it to work.
Any help will be greatly appreciated… thanks!
Here is the code I’m using:
Sub displayVideo(doc As NotesDocument)
On Error Goto errHandling
Dim sess As New NotesSession
Dim db As NotesDatabase
Dim videoHTML As String
Set db = sess.CurrentDatabase
videoHTML = VideoField
Exit Sub
errHandling:
Print Err & " - " & Error & " on line " & Erl
Resume Next
