I have names field and Lookup address on document fresh check box is enabled. The value of this field gets inherited to authors and readers field. But whenever I click F9, value is names field gets appended with text @ and becuase of this my authors and readers field are not functioning properly.
I did tried using @Name([canonicalize];), but its not working.
Can anyone please tell me why names fields are getting appended to @
Thanks,
Ranjana
Subject: Names fields problem
Have you tried using @Names([CN])??
The domain is sometimes appended because of the lookup to the NAB which specifies domain. Using CN should sort this out.
Subject: RE: Names fields problem
Will following formula in input translation of field will give problem
@If(@Contains(@ThisValue;“@”);@Left(@ThisValue;“@”);@ThisValue)
Thanks,
Ranjana
Thanks for reply.
But I cannot user [CN], as there are few entries in address book which has same common name but different full name. I that case putting [cn] in authors or readers will give access to all users who has same common name.
Thanks & Regards,
Ranjana
