Mozila Firefox Problem
Hi,I have developed a web-based application.Its run well in IE but when i m going to open in Mozila Firefox,some icon of the header(Home page are missing).The header menu contain Profile,home,Certification,help,logout.The log out menu is the last menu in the header.And when i run it in mozila,the logout menu is not showing but the rest are showin in the Headed.
What the problem with me.
Subject: Mozila Firefox Problem
hIThe code which i have written in is
// Ultimate client-side JavaScript client sniff. Version 3.03
// (C) Netscape Communications 1999. Permission granted to reuse and distribute.
// Revised 17 May 99 to add is.nav5up and is.ie5up (see below).
// Revised 21 Nov 00 to add is.gecko and is.ie5_5 Also Changed is.nav5 and is.nav5up to is.nav6 and is.nav6up
// Revised 22 Feb 01 to correct Javascript Detection for IE 5.x, Opera 4,
// correct Opera 5 detection
// add support for winME and win2k
// synch with browser-type-oo.js
// Revised 26 Mar 01 to correct Opera detection
// Revised 02 Oct 01 to add IE6 detection
// Everything you always wanted to know about your JavaScript client
// but were afraid to ask … “Is” is the constructor function for “is” object,
// which has properties indicating:
// (1) browser vendor:
// is.nav, is.ie, is.opera,is.mozila, is.hotjava, is.webtv, is.TVNavigator, is.AOLTV
// (2) browser version number:
// is.major (integer indicating major version number: 2, 3, 4 …)
// is.minor (float indicating full version number: 2.02, 3.01, 4.04 …)
// (3) browser vendor AND major version number
// is.nav2, is.nav3, is.nav4, is.nav4up, is.nav6, is.nav6up, is.gecko, is.ie3,
// is.ie4, is.ie4up, is.ie5,is.mozila11.5, is.ie5up, is.ie5_5, is.ie5_5up, is.ie6, is.ie6up, is.hotjava3, is.hotjava3up
// (4) JavaScript version number:
// is.js (float indicating full JavaScript version number: 1, 1.1, 1.2 …)
// (5) OS platform and version:
// is.win, is.win16, is.win32, is.win31, is.win95, is.winnt, is.win98, is.winme, is.win2k
// is.os2
// is.mac, is.mac68k, is.macppc
// is.unix
// is.sun, is.sun4, is.sun5, is.suni86
// is.irix, is.irix5, is.irix6
// is.hpux, is.hpux9, is.hpux10
// is.aix, is.aix1, is.aix2, is.aix3, is.aix4
// is.linux, is.sco, is.unixware, is.mpras, is.reliant
// is.dec, is.sinix, is.freebsd, is.bsd
// is.vms
// See it97.de steht zum Verkauf and
// it97.de steht zum Verkauf
// for detailed lists of userAgent strings.
// Note: you don’t want your Nav4 or IE4 code to “turn off” or
// stop working when Nav5 and IE5 (or later) are released, so
// in conditional code forks, use is.nav4up (“Nav4 or greater”)
// and is.ie4up (“IE4 or greater”) instead of is.nav4 or is.ie4
// to check version in code which you want to work on future
// versions.
function Is ()
{ // convert all characters to lowercase to simplify testing
var agt=navigator.userAgent.toLowerCase();
// *** BROWSER VERSION ***
// Note: On IE5, these return 4, so use is.ie5up to detect IE5.
this.major = parseInt(navigator.appVersion);
this.minor = parseFloat(navigator.appVersion);
// Note: Opera and WebTV spoof Navigator.  We do strict client detection.
// If you want to allow spoofing, take out the tests for opera and webtv.
this.nav  = ((agt.indexOf('mozilla')!=-1) && (agt.indexOf('spoofer')==-1)
            && (agt.indexOf('compatible') == -1) && (agt.indexOf('opera')==-1)
            && (agt.indexOf('webtv')==-1) && (agt.indexOf('hotjava')==-1));
this.nav2 = (this.nav && (this.major == 2));
this.nav3 = (this.nav && (this.major == 3));
this.nav4 = (this.nav && (this.major == 4));
this.nav4up = (this.nav && (this.major >= 4));
this.navonly      = (this.nav && ((agt.indexOf(";nav") != -1) ||
                      (agt.indexOf("; nav") != -1)) );
this.nav6 = (this.nav && (this.major == 5));
this.nav6up = (this.nav && (this.major >= 5));
this.gecko = (agt.indexOf('gecko') != -1);
this.ie     = ((agt.indexOf("msie") != -1) && (agt.indexOf("opera") == -1));
this.ie3    = (this.ie && (this.major < 4));
this.ie4    = (this.ie && (this.major == 4) && (agt.indexOf("msie 4")!=-1) );
this.ie4up  = (this.ie  && (this.major >= 4));
this.ie5    = (this.ie && (this.major == 4) && (agt.indexOf("msie 5.0")!=-1) );
this.ie5_5  = (this.ie && (this.major == 4) && (agt.indexOf("msie 5.5") !=-1));
this.ie5up  = (this.ie  && !this.ie3 && !this.ie4);
this.ie5_5up =(this.ie && !this.ie3 && !this.ie4 && !this.ie5);
this.ie6    = (this.ie && (this.major == 4) && (agt.indexOf("msie 6.")!=-1) );
this.ie6up  = (this.ie  && !this.ie3 && !this.ie4 && !this.ie5 && !this.ie5_5);
// KNOWN BUG: On AOL4, returns false if IE3 is embedded browser
// or if this is the first browser window opened.  Thus the
// variables is.aol, is.aol3, and is.aol4 aren't 100% reliable.
this.aol   = (agt.indexOf("aol") != -1);
this.aol3  = (this.aol && this.ie3);
this.aol4  = (this.aol && this.ie4);
this.aol5  = (agt.indexOf("aol 5") != -1);
this.aol6  = (agt.indexOf("aol 6") != -1);
this.opera = (agt.indexOf("opera") != -1);
this.opera2 = (agt.indexOf("opera 2") != -1 || agt.indexOf("opera/2") != -1);
this.opera3 = (agt.indexOf("opera 3") != -1 || agt.indexOf("opera/3") != -1);
this.opera4 = (agt.indexOf("opera 4") != -1 || agt.indexOf("opera/4") != -1);
this.opera5 = (agt.indexOf("opera 5") != -1 || agt.indexOf("opera/5") != -1);
this.opera5up = (this.opera && !this.opera2 && !this.opera3 && !this.opera4);
this.webtv = (agt.indexOf("webtv") != -1);
this.TVNavigator = ((agt.indexOf("navio") != -1) || (agt.indexOf("navio_aoltv") != -1));
this.AOLTV = this.TVNavigator;
this.hotjava = (agt.indexOf("hotjava") != -1);
this.hotjava3 = (this.hotjava && (this.major == 3));
this.hotjava3up = (this.hotjava && (this.major >= 3));
// *** JAVASCRIPT VERSION CHECK ***
if (this.nav2 || this.ie3) this.js = 1.0;
else if (this.nav3) this.js = 1.1;
else if (this.opera5up) this.js = 1.3;
else if (this.opera) this.js = 1.1;
else if ((this.nav4 && (this.minor <= 4.05)) || this.ie4) this.js = 1.2;
else if ((this.nav4 && (this.minor > 4.05)) || this.ie5) this.js = 1.3;
else if (this.hotjava3up) this.js = 1.4;
else if (this.nav6 || this.gecko) this.js = 1.5;
// NOTE: In the future, update this code when newer versions of JS
// are released. For now, we try to provide some upward compatibility
// so that future versions of Nav and IE will show they are at
// *least* JS 1.x capable. Always check for JS version compatibility
// with > or >=.
else if (this.nav6up) this.js = 1.5;
// note ie5up on mac is 1.4
else if (this.ie5up) this.js = 1.3
// HACK: no idea for other browsers; always check for JS version with > or >=
else this.js = 0.0;
// *** PLATFORM ***
this.win   = ( (agt.indexOf("win")!=-1) || (agt.indexOf("16bit")!=-1) );
// NOTE: On Opera 3.0, the userAgent string includes "Windows 95/NT4" on all
//        Win32, so you can't distinguish between Win95 and WinNT.
this.win95 = ((agt.indexOf("win95")!=-1) || (agt.indexOf("windows 95")!=-1));
// is this a 16 bit compiled version?
this.win16 = ((agt.indexOf("win16")!=-1) ||
           (agt.indexOf("16bit")!=-1) || (agt.indexOf("windows 3.1")!=-1) ||
           (agt.indexOf("windows 16-bit")!=-1) );
this.win31 = ((agt.indexOf("windows 3.1")!=-1) || (agt.indexOf("win16")!=-1) ||
                (agt.indexOf("windows 16-bit")!=-1));
// NOTE: Reliable detection of Win98 may not be possible. It appears that:
//       - On Nav 4.x and before you'll get plain "Windows" in userAgent.
//       - On Mercury client, the 32-bit version will return "Win98", but
//         the 16-bit version running on Win98 will still return "Win95".
this.win98 = ((agt.indexOf("win98")!=-1) || (agt.indexOf("windows 98")!=-1));
this.winnt = ((agt.indexOf("winnt")!=-1) || (agt.indexOf("windows nt")!=-1));
this.win32 = (this.win95 || this.winnt || this.win98 ||
                ((this.major >= 4) && (navigator.platform == "Win32")) ||
                (agt.indexOf("win32")!=-1) || (agt.indexOf("32bit")!=-1));
this.winme = ((agt.indexOf("win 9x 4.90")!=-1));
this.win2k = ((agt.indexOf("windows nt 5.0")!=-1));
this.os2   = ((agt.indexOf("os/2")!=-1) ||
                (navigator.appVersion.indexOf("OS/2")!=-1) ||
                (agt.indexOf("ibm-webexplorer")!=-1));
this.mac    = (agt.indexOf("mac")!=-1);
// hack ie5 js version for mac
if (this.mac && this.ie5up) this.js = 1.4;
this.mac68k = (this.mac && ((agt.indexOf("68k")!=-1) ||
                           (agt.indexOf("68000")!=-1)));
this.macppc = (this.mac && ((agt.indexOf("ppc")!=-1) ||
                            (agt.indexOf("powerpc")!=-1)));
this.sun   = (agt.indexOf("sunos")!=-1);
this.sun4  = (agt.indexOf("sunos 4")!=-1);
this.sun5  = (agt.indexOf("sunos 5")!=-1);
this.suni86= (this.sun && (agt.indexOf("i86")!=-1));
this.irix  = (agt.indexOf("irix") !=-1);    // SGI
this.irix5 = (agt.indexOf("irix 5") !=-1);
this.irix6 = ((agt.indexOf("irix 6") !=-1) || (agt.indexOf("irix6") !=-1));
this.hpux  = (agt.indexOf("hp-ux")!=-1);
this.hpux9 = (this.hpux && (agt.indexOf("09.")!=-1));
this.hpux10= (this.hpux && (agt.indexOf("10.")!=-1));
this.aix   = (agt.indexOf("aix") !=-1);      // IBM
this.aix1  = (agt.indexOf("aix 1") !=-1);
this.aix2  = (agt.indexOf("aix 2") !=-1);
this.aix3  = (agt.indexOf("aix 3") !=-1);
this.aix4  = (agt.indexOf("aix 4") !=-1);
this.linux = (agt.indexOf("inux")!=-1);
this.sco   = (agt.indexOf("sco")!=-1) || (agt.indexOf("unix_sv")!=-1);
this.unixware = (agt.indexOf("unix_system_v")!=-1);
this.mpras    = (agt.indexOf("ncr")!=-1);
this.reliant  = (agt.indexOf("reliantunix")!=-1);
this.dec   = ((agt.indexOf("dec")!=-1) || (agt.indexOf("osf1")!=-1) ||
              (agt.indexOf("dec_alpha")!=-1) || (agt.indexOf("alphaserver")!=-1) ||
              (agt.indexOf("ultrix")!=-1) || (agt.indexOf("alphastation")!=-1));
this.sinix = (agt.indexOf("sinix")!=-1);
this.freebsd = (agt.indexOf("freebsd")!=-1);
this.bsd = (agt.indexOf("bsd")!=-1);
this.unix  = ((agt.indexOf("x11")!=-1) || this.sun || this.irix || this.hpux ||
             this.sco ||this.unixware || this.mpras || this.reliant ||
             this.dec || this.sinix || this.aix || this.linux || this.bsd || this.freebsd);
this.vms   = ((agt.indexOf("vax")!=-1) || (agt.indexOf("openvms")!=-1));
var is;
var isIE3Mac = false;
is = new Is()
Pls help me where i have done mistake so that it doesn’t work in Mozila.
Waiting 4 replay…
