Hi,I´ve got the following message in the
Monitoring Results (statrep.nsf) database.
Monitor Error in Database /LOTUS/DOMINO/server/mail/xxs.nsf: Entry not found in index >>
The maildatabase is ok; what does this message means ?
Thanks for your help.
Stefanie
Subject: Monitor Error in Database /LOTUS/DOMINO/SYS0099N/mail/xxs.nsf: Entry not found in index
Me to. It’s happening frequently. I do notice that the database has a clean up agent on it to delete messages older than 30 days. But everything appears to be working. There is noting in the events4.nsf database that anything is “monitoring” or probing the database.
Let me know if you find anything
Subject: RE: Monitor Error in Database /LOTUS/DOMINO/SYS0099N/mail/xxs.nsf: Entry not found in index
Just incase someone else has the same problem…
Check the mail rules for the mail file in question…you will very likely find a rule is setup to file emails into a folder that no longer exists/has been renamed.
