MIMEEntity, setContentFromText: body disappearing
Is it possible to use MIMEEntity.setContentFromText to modify an existing text/html part of an existing mime/multipart Body?
I have a Document with a RichText item (called Body) and other fields. Body has “store content as html and mime” property set.
I need to modify the Notes generated html for Body, and SAVE it (not send).
I’m using java, and MIMEEntity.setContentFromText().
It works for local databases (with 1 attachment), but if I run it on a db located on server (via Notes),
and the document has attachments, the Body disappears: no empty body, there isn’t any item called body!
With more than 1 attachment (on local db), the attachments collapse: I get a 30kb big file instead of 3 10kb small files.
I tried with a java agent like:
boolean bCM = session.isConvertMime();
session.setConvertMime(false);
Document noteThis = agentContext.getDocumentContext();
try {
MIMEEntity mime = noteThis.getMIMEEntity();
doMIMEExploration(session, mime);
noteThis.save(true, false);
} catch…
session.setConvertMime(bCM);
public void doMIMEExploration(Session sessThis, MIMEEntity mime) throws Exception {
if (mime != null) {
    if (isTextHTMLAndNotAttachment(mime)) {
        try {
            String sBody4 = mime.getContentAsText();
            String sConvertedBody = MIMEConverter.convertText(sBody4); // a class of mine
            if (sConvertedBody != null) {
                Stream str = sessThis.createStream();
str.writeText(sConvertedBody);
//1=chr(10), 2=chr(13), 0=chr(13)+chr(10)
str.writeText(“”, 0); str.writeText(“”, 0);
					mime.setContentFromText(str, "text/html; charset=\"iso-8859-1\"", MIMEEntity.ENC_IDENTITY_8BIT);
					str.close();
        } catch...
    doMIMEExploration(sessThis, mime.getFirstChildEntity());
    doMIMEExploration(sessThis, mime.getNextSibling());
Domino 6.5.3 on Windows, 6.5.1 on Win and Linux, Notes 6.5.3.
Any ideas?
Thanks,
stefano
