Memory problems in client?
I am running Notes 6.5.2 on Windows XP SP1. The PC is a 2.4GHz P4 with 1Gb RAM. The paging file size is set to 1531Mb (initial, recommended) with a maximum size of 2048Mb.
I am frequently experiencing the client hanging for long periods of time (30 - 40 seconds or longer). This can be simply having hit return whilst typing an email. When I check task manager the CPU is showing as 100% utilised. But when the individual processes are checked there are no processes using any of the CPU.
I assume there is something wrong with either the install of the client or with settings on the PC. Can anyone suggest what I should be checking for? Thanks in advance.
*Update. On further investigation it seems that the CPU hits 100% usage when I open my mailbox which is located on a server. Could the problem be on the server, and be affecting the PC?
