MakeResponse problem
Hi all,I am getting Type mismatch compile error when using makeresponse method in the following code in an agent initialize method.
Dim db As NotesDatabase
Dim view As NotesView
Dim doc, respdoc As NotesDocument
Set view = db.GetView(“persons”)
While Not(doc Is Nothing)
        Set respdoc = db.CreateDocument()
Call respdoc.MakeResponse( doc )
			respdoc.form = "respform"
			Call respdoc.Save(True, False)
Wend
I also tried savinf respdoc before using makerespose, but that gave the same error too.
Please somebody help.
Subject: Your problem is this Line: Dim doc, respdoc As NotesDocument
That essentially compiles to Dim doc As Variant, respdoc As NotesDocumentWhat you need is:
Dim doc As NotesDocument, respdoc As NotesDocument
Subject: That was it!
Thanks Bill.
