I have installed and configured the DAMO but there is a security problem that I can not seem to figure out. I have set the permissions in the Domino Preferences under Outlook, Tools - Options to only access Calendar & To Do tasks. I have also set the permissions in the other user's DAMO. However, the user's mail items are also accessible. This presents a serious security issue. Is there ANY way to prevent Mail access while still being able to view the Calendar/To Do information. Any help regarding possible ACL settings/DAMO client settings/Mail file settings etc. would be greatly appreciated.
If removing the viewabilty mail items is not possible then this is a serious security flaw in DAMO. It should be addressed by Notes personnel as soon as possible because the options specifically state Calendar & To Do items ONLY.
Subject: Major DAMO Security Problem
You should check the ACL on the mailfile of the person whose mail items you can see. The user who is granted access to view their calendar items should only have “read public document” checked. This should give them access to calendar documents not marked private, but not private calendar docs or email.
If this doesn’t work, you should contact Lotus Support. This Forum is for users (typically dev/admin), and you won’t get bug fixes from “Notes personnel” here.
Hi Rick,
What you are probably seeing is the results of previosly syncronized emails when the delegatee’s access was not limited to read-only of calendar and to do’s. Be aware that the file that Oulook is using is a local file (.pst) that will contain whatever docs that were in there before restricting access.
Another possibility is that during initial replication of the managed calendar, the delegated user will be seeing accepted and declined calendar entries in the Inbox folder. These are calendar related docs and may be displayed in the Inbox. (For the next release of DAMO this annoyance is being addressed but this is not a security concern as these are calendar docs.)
Domino security has been around for a long time and DAMO cannot override this security. There are a couple of things to look at to make youself comfortable with the delegation process. First, once the manager assigns a delegatee, the ACL of the manager’s mail file is changed to permit the delegatee access. If the manager has Manager access to his own mail file, then that ALC change takes place right away. If the manager has less than Manager access to his own mail file, then the process of changing the manager’s ACL will need to be addressed by the server’s Administration Process which can take time.
In any event, you can confirm the correct access by looking at the manager’s mail file ACL. For the read-only of calendar and to do’s, the delegated user will appear in the ACL as Unspecified with No Access. Read Public Docs and Replicate Public docs will be enabled.
Thanks, Mike
