MailFile on local replica...Having problems ...when I open it---Please help
Hi All,
Suddenly I got an error when I open my mailbox on local.(which replicates with the server)
Here is the message “The view is being updated. It will display as soon as the update completes. You can continue working with other windows while the view is updating”
Please help how to get rid of this error…This erro is on since 8 hrs. I just checked the server and tried to Ping it and it sent me the reply .
Please help, how to get rid of this error.
Thanks in advance,
ac ac
Subject: MailFile on local replica…Having problems …when I open it—Please help
I wouldn’t say this was an error as such, this message is given when the view is being built, this function allows you to continue to work on another view whilst it is being built.
As this is local I would bring up a DOS prompt and go to the Notes program directory. Then run ’ nupdall -R directory\filename.nsf ’
Start the client and see if it now works ok.
