Hello,
I have problems when synchronising my mail with my PocketPC 2003.
The mails don’t go in the right folder :
for instance, the Inbox mail in Notes goes to the draft folder in the PocketPC, etc…
Have you ever experienced such a problem ?
Does any of you use this configuration without any problem ?
I know that PocketPC 2003 is not supported so far. Do you know whether there is a planned released version for this support ?
Thank you for your help.
And Best Wishes for 2004 !
Stephane
Subject: Mail problem with EasySync 4.2 and PocketPC 2003
see also (“EasySync 3.0 and R6” Posted by Orlando Pereira on 04.11.2003) with similar posting. Try Commontime mNotes (http://www.commontime.com) instead.
Regards,
Dirk
Subject: RE: Mail problem with EasySync 4.2 and PocketPC 2003
I’ve had similar problems syncing with easysync (inbox–>drafts). And also various other problems with activesync/easysync. At the moment I’m evaluating Pylon Pro, and it looks promising so far. Better integrated in activesync as wel as in notes.
