I have several servers in the same location. They are all connected to the same network switch.
All the servers have connection docs set to route mail if 1 message pending.
When SMTP is delivered to server A, some of it will be routed to the correct server (B or C), but some of it will sit there. If I type route “server-name” the mail is delivered straight away.
Is there another setting somewhere that over rides this? Can I add more message router threads to improve mail delivery handling?
Thanks in advance for your help
Neil
Subject: Don’t bother with Connection documents. Put all the servers…
in the same Notes Network - Server doc, Ports, Notes Network Ports:
Port
Protocol
Notes Network
Net Address
Enabled
TCPIP
TCP
MakeSameforallServers
YourServer
ENABLED
Subject: RE: Don’t bother with Connection documents. Put all the servers…
All the servers on the LAN are in the same Notes Network. If I don’t have any connection docs, no mail at all is routed.
Subject: Then something is really wrong. Notes mail routing since V1 has worked like this.
Are they in different Domains? Same replica of the NAB on all?
Subject: That is what I was afraid of
They are both in the same domain & share he address book.
Do you have any advice to where I should start?
Thanks in advance for all your help
Neil
Subject: RE: That is what I was afraid of
Actually, it hasn’t worked like this since V1 because V1 had no SMTP service.
There’s lots of info needed before being able to think intelligently about this problem.
You have the SMTP Listener going. Have you enabled SMTP routing?
Do you know if you are using Notes mail or SMTP mail for internal routing?
Are you using IP addresses or DNS names in the Ports Net Address setting?
Is DNS setup properly? Do DNS request for internal servers return internal IP addresses?
Is NetBIOS enabled on the NICs? Is LAN0 enabled on the servers?
What server name do you use in the route command? DNS name? Canonical name?
Have you followed the instructions in the Administrators Help for setting up SMTP mail?
Subject: No, he is talking about interal NRPC routing of mail from his SMTP Inbound ServerA.
Subject: That what you and I assume.
What I’m trying to determine is if HE understands the difference, and what, exactly has he done to the server Configuration document in attempts to fix the problem. You know, people look at settings and start thinking “well maybe if I enable this, that, and the other thing…”
