LS Code Problem - Help needed and appreciated
The code below should be assigning a bid number but it’s assigning the field as Draft, does anyone happen to know why?
There are no other entries in this db, it’s the first one.
There a bit more code below what I’ve put to do with something else. I’ve missed this off as the code above is the problem.
Thanks,
Hayley.
'-- Generate Bid number - based on a combination of
'-- Yr + Centre + Bid Sequence number
Dim db As NotesDatabase
Dim doc As NotesDocument
Dim doc1 As NotesDocument
Dim curdoc As NotesDocument
Dim BidNumDoc As NotesDocument
Dim ClientAbbrView, BidNumView As NotesView
Dim column As NotesViewColumn
Dim DivAbbrev As Variant                             ' Division Abbreviation
Dim BidYear As Variant
Dim SeqNum, SeqNum1 As Variant
Dim SeqNumInt As Integer
Dim uidoc As NotesUIDocument
Dim vc As NotesViewEntryCollection
Dim entry As NotesViewEntry
Set uidoc = workspace.CurrentDocument
Set curdoc = uidoc.Document
Set BidNumView = db.GetView("BidNum")
Set doc=uidoc.document
SeqNum1 = ""
uidoc.EditMode = True
clientkey = curdoc.Centre(0)
YrBidNum = Evaluate("@Year(DueDate)", curdoc)
Set vc = BidNumView.GetAllEntriesByKey(YrBidNum(0))
If Not(vc.Count = 0) Then
	Set entry = vc.GetLastEntry()
	Set doc = entry.Document
	If Not(doc Is Nothing) Then
		SeqNum1 = Right$(doc.FileNumber(0), 3)           'ColumnValues(0)
If SeqNum1 = "" Then
	SeqNum = "0"
Else
	SeqNum = SeqNum1
If SeqNum = "" Then
	SeqNum = "-1"
SeqNumInt = Clng(SeqNum)
SeqNum = Right$("00" & Cstr(SeqNumInt + 1),3)
BidYear = Right$(YrBidNum(0),1)
BidNum = BidYear + SeqNum
Call uidoc.FieldSetText( "FileNumber", Cstr(BidNum))
Subject: LS Code Problem - Help needed and appreciated.
Here it is:
Sub Click(Source As Button)
SeqNum1 = ""
'-- Error checks
If Not(curdoc.FileNumber(0) = "") And Not(curdoc.FileNumber(0) = "Draft") Then
	Msgbox("Bid already has a number assigned to it")
	Exit Sub
If (uidoc.FieldGetText("Client") = "") Then
	Msgbox("You must enter a value for Client")
	Call uidoc.GotoField( "Client" )
	continue = False
	Exit Sub
If (uidoc.FieldGetText("Centre") = "") Then
	Msgbox("You must enter a value for Centre")
	Call uidoc.GotoField( "Centre" )
	continue = False
	Exit Sub
If (uidoc.FieldGetText("Country") = "") Then
	Msgbox("You must enter a value for Country")
	Call uidoc.GotoField( "Country" )
	continue = False
	Exit Sub
If (uidoc.FieldGetText("Region") = "") Then
	Msgbox("You must enter a value for Sub-Region via the Country field")
	continue = False
	Exit Sub
If ( uidoc.FieldGetText( "DueDate" ) = "" ) Then
	Msgbox("You must enter a Due Date for the Bid")
	Call uidoc.GotoField( "DueDate" )
	continue = False
	Exit Sub
'-- END Error checks
	SeqNum = "0"
Else
	SeqNum = SeqNum1
If SeqNum = "" Then
	SeqNum = "-1"
%REM
Author:			Hayley Kenward
Date: 			11 April 2005
Description:	Moved the approval scripts section from QuerySave to this button.
Sections:		1)Sends the QC Approval email to the relevant people
Modified Date:
%END REM
If ( Trim(curdoc.EmailStatus(0)) <> "" ) Then
	Dim user As String
	Dim Num As Double
	Dim aString As String
	doc.QCToggle="Yes"
	user=session.UserName
	BidNumber=uidoc.FieldGetText("FileNumber")
	uidoc.Refresh
' Sends the QC Approval email to the relevant people
	Dim newdoc As NotesDocument
	Set newdoc=New NotesDocument(db)
	Dim rtitem As NotesRichTextItem
	Set rtitem=New NotesRichTextItem(newdoc,"Body")
	newdoc.Form="Memo"
	newdoc.SendTo=doc.QCApprovalSendTo
	newdoc.CopyTo=doc.user
	newdoc.Subject="QC Approval required for Bid Number " & BidNumber
	uidoc.Refresh
	Call doc.Save(True,False)
	Call rtitem.AddNewLine(2)
	Call rtitem.AppendText("The Bid number referenced above is ready for QC")
	Call rtitem.AppendText("This will register the date and name of the approver.")
	Call rtitem.AddNewLine(4)
	Call rtitem.AppendText("Bid No				")
	Call rtitem.AppendText(doc.FileNumber(0))
	Call rtitem.AddNewLine(1)
	Call rtitem.AppendText("Status				")
	Call rtitem.AppendText(doc.Status(0))
	Call rtitem.AppendText("Client				")
	Call rtitem.AppendText(doc.Client(0))
	Call rtitem.AppendText("Country				")
	Call rtitem.AppendText(doc.Country(0))
	Call rtitem.AppendText("Survey Size			")
	Call rtitem.AppendText(doc.Volume(0))
	Call rtitem.AppendText("Survey Type			")
	Call rtitem.AppendText(doc.Dimension(0))
	Call rtitem.AppendText("Bid Total			")
	Call rtitem.AppendText(doc.BidTotal(0))
	Call rtitem.AppendText("Contact				")
	Call rtitem.AppendText(doc.VeritasContact(0))
	Call rtitem.AppendText("Chance of winning		")
	Call rtitem.AppendText(doc.Significance(0))
	Call rtitem.AppendText("Comments			")
	Call rtitem.AppendText(doc.Comments(0))
	Call rtitem.AppendText("Please follow link to view bid ->>  ")
	Call rtitem.AppendDocLink(doc,db.Title)
	Call newdoc.Send(False)
Call uidoc.Save
Call uidoc.Close
Exit Sub
ErrorHandler:
Messagebox "Bid Number Error - Could not generate a Bid Number, Please contact your database administrator"
Continue=False
Exit Sub
Call uidoc.Save
Call uidoc.Close
Exit Sub
Sorry, in the QuerySave event, I have this code:
If ( source.FieldGetText( "FileNumber" ) = "" ) Then
	Call source.FieldSetText( "FileNumber", "Draft" )
So it means the Assign Bid Number button, which the code is in my first post is not working correctly, because it should be assigning a bid number and not Draft.
Subject: RE: LS Code Problem - Help needed and appreciated.
hmm
Can you post the rest of the button code? I can’t see anything in that off the top of my head.
also, does the field value change after the button has been pressed? Are there any validation/translation formulae on the FileNumber field?
Kieran
Can you explain what you mean by “Its assigning the field as Draft”?
THanks
Kieran
